RT3_Telecodare
gabi_1050
Marca si model masina:Peugeot 5O8 GT 2O4cp
ex car:407,1.6hdi,80kw
Localitate:Deva
RT3_Telecodare
Mesaj de gabi_1050 » Joi Noi 28, 2013 10:40 pm
Se da navigatia Magneti Marelli seria 9663291777,vers.soft 6.62,fabricata la 07.01.2007
Navigatia trebuie configurata pentru VF36DRHRH2109XXXX,Rpo/dam 10168 .
Imagine Imagine Imagine
Caracteristicile vehiculului VF36DRHRH2109XXXX,Rpo/dam 10168
Linie de produs 407
Nr. APV/PR 10168 CJ 2 0457
Data de Inceput de Garantie 20.10.2004
NRE e2*2001/116*0297*02
Informatii generale
GENRE DE PRODUIT VEHICUL PARTICULAR
MARQUE COMMERCIALE, TYPE ORGANE PEUGEOT
LIGNE DE PRODUIT 407
SILHOUETTE BERLINA 4 USI
FINITION PACHET HS
MOTEUR DIESEL TURBO DW10BTED4 FILTRU DE PARTICULE
TRANSMISSION CUTIE DE VITEZE MANUALA6
TYPE DE PEINTURE VOPSEA METALIZATA LACUITA
COULEUR DE CAISSE EZW - VOPSEA GRI FER
TYPE D’HABILLAGE INTÉRIEUR PIELE GRAIN CLAUDIA L019 "CY"
COULEUR DE GARNISSAGE "FT"
BOITE DE VITESSES (CARACTÉRISTIQUES) CUTIE DE VITEZE MANUALA ML6 CL
MOTEUR (TYPE) MOTOR TIP EW/DW
Caracteristici vehicul
FINITION PACHET HS
DIRECTION MECANISM DE DIRECTIE ASISTATA CARE NU ESTE VARIABILA
Alimentare motor
DÉTECTEUR D’EAU FILTRE À GAZOLE CU SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
CARBURANT MOTORINA
DÉPOLLUTION (MOTEUR) DEPOLUARE EURO 4 (MOTOR)
REFROIDISSEMENT D’HUILE SCHIMBATOR APA/ULEI MOTOR
RÉCHAUFFAGE CIRCUIT GAZ CARTER FARA SISTEM DE INCALZIRE CIRCUIT DE GAZE CARTER
VARIATION PUISSANCE (MOTEUR) PUTERE STANDARD
AUTODIAGNOSTIC EOBD SISTEM DE AUTODIAGNOSTICARE "EOBD"
DISPOSITIF (ANTIPOLLUTION) RECIRCULARE GAZE DE ESAPAMENT "EGR"
DÉPOLLUTION TECHNIQUE VÉHICULE DEPOLUARE TEHNICA VEHICUL EURO4
FILTRE À PARTICULE FILTRU DE PARTICULE
VENTILATEUR 1 VENTILATOR ELECTRONIC CU COMANDA INTEGRATA 150W
VARIANTE ASSOCIÉE INJECTION SISTEM INJECTIE SIEMENS
FILTRE RÉSERVOIR FARA FILTRU REZERVOR
BOÎTIER PAPILLON (ADMISSION AIR MOTEUR) MODUL CLAPETA MOTORIZATA (ADMISIE AER MOTOR)
Cutie de viteze - Transmisie
COUPLE RAPPORT RAPORT PUNTE 17 X 71
STYLE ROUE ROATA QUAZAR 17 INCI
EMBRAYAGE AMBREIAJ HIDRAULIC
DIFFÉRENTIEL (BOITE) DIFERENTIAL 86
JANTE / PNEU DIMENSION ECHIPARE PNEU 17 INCI
PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 215X55X17 W
ROUE (TYPE) MONTARE ROATA ALIAJ 2
INDICATEUR DE PERTE DE PRESSION DE GONFLAGE INDICATOR PIERDERE PRESIUNE PNEURI
BOITE DE VITESSES TYPE ML6C
Suspensie - directie - Franare
COLONNE DIRECTION COLOANA DE DIRECTIE CU REGLARE MANUALA
ANTIDÉVERS AVANT BARA ANTIRULIU FATA DIAMETRU 24
COURSE MÉCANISME DE DIRECTION CURSA MECANISM DE DIRECTIE 174
SUSPENSION ACTIVE FARA SUSPENSIE VARIABILA
CONTRÔLE DYNAMIQUE DE STABILITÉ CU SISTEM ESP
DIRECTION (FONCTIONNEMENT) DIRECTIE ASISTATA ELECTROHIDRAULIC
Caroserie Echipamente
ATTACHE-REMORQUE FARA DISPOZITIV DE REMORCARE
ENJOLIVEMENT LATÉRAL (ASPECT) ELEMENTE PROTECTIE LATERALA VOPSITE IN MASA + CROMATE
ENJOLIVEMENT LATÉRAL (DIMENSION) ELEMENTE DE PROTECTIE LATERALE + TREAPTA
ENJOLIVEUR ROUE (STYLE) FARA CAPAC DE ROATA
FEU D’ÉCLAIRAGE DE SEUIL LUMINA PENTRU PRAG
COMPLÉMENT DE PROTECTION (SOUS MOTEUR) FARA PROTECTIE SUPLIMENTARA SUB MOTOR
FONCTION COMPLÉMENTAIRE RÉTROVISEUR EXTÉRIEUR RETROVIZOR EXTERIOR RABATABIL ELECTRIC FARA MEMORIE
ESSUIE-VITRE AVANT MECANISM STERGERE PARBRIZ CU SENZOR DE PLOAIE
ESSUIE-VITRE ARRIÈRE FARA MECANISM DE STERGERE LUNETA
ESSUIE-PROJECTEUR MECANISM DE STERGERE PROIECTOR
OBTURATEUR FACE AVANT FARA OBTURATOR PARTE FRONTALA FATA
VITRE PAVILLON FARA ELEMENT VITRAT DE PAVILION
ROUE DE SECOURS ROATA JANTA TABLA + PNEU STANDARD
ACCESSOIRES EXTÉRIEURS MANERE EXTERIOARE + RETROVIZOARE EXTERIOARE CULOARE CAROSERIE
TOIT OUVRANT ACOPERIS FIX
ENJOLIVEMENT PARE-CHOCS BANDOU DE BARA DE PROTECTIE COLORAT IN MASA + ORNAMENT INOX
VITRE (ASPECT) GEAM FUMURIU
VITRE (TYPE) PARBRIZ + GEAMURI LATERALE STRATIFICATE + LUNETA SECURIZATA
ACCÈS ET DÉMARRAGE MAINS LIBRES FARA ACCCES SI PORNIRE MAINI LIBERE
Echipament interior
ALARME ANTIVOL ALARMA PENTRU VOLUM + PERMETRU - STANDARD
ACCOUDOIR ASSISE ARRIÈRE CU COTIERA SPATE
CEINTURE DE SÉCURITÉ ARRIÈRE CENTURI DE SIGURANTA PIROTEHNICE LATERAL SPATE CU RETRACTOR + CENTURA IN 3 PUNCTE
CLIMAT (TEMPÉRATURE AMBIANTE) TARI CU CLIMA RECE
CONDAMNATION ENFANT SIGURANTA COPIL USI SPATE CU COMANDA ELECTRICA
GRADUATION VITESSES GRADATIE IN KM/H
COTÉ DE CONDUITE (POSTE DE CONDUITE) VOLAN PE STANGA
CHAUFFAGE ADDITIONNEL FARA SISTEM DE INCALZIRE SUPLIMENTAR
EQUIPEMENT PLANCHE DE BORD PLANSA DE BORD STANDARD + FATADA DECORATIUNE LEMN
COMBINÉ (CARACTÉRISTIQUES) GRADATIE 260 KM/H 160 M/H FUNDAL NEGRU
GARNISSAGE DE PORTE DECORATIUNE LEMN
HAUT-PARLEUR 4 DIFUZOARE FATA (2 TWEETERE + 2 DIFUZOARE) + 5 DIFUZOARE SPATE (2 TWEETERE + 2 DIFUZOARE + 1 SUBWOOFER)
COMMANDE D’AUTORADIO COMANDA SISTEM AUDIO LA DISTANTA
ISOLATION (RIDEAU, PARE-SOLEIL LATÉRAL, TOIT OUVRANT) TRANSPERANT SPATE CU COMANDA MANUALA
REHAUSSE ASSISE AVANT PASSAGER DISPOZITIV DE INALTARE PERNA PASAGER REGLARE PARALELA + AVANSARE
COMMANDE ASSISE AVANT CONDUCTEUR COMANDA ELECTRICA SCAUN CONDUCATOR
COMMANDE ASSISE AVANT PASSAGER COMANDA ELECTRICA SCAUN PASAGER FATA
RÉGLAGE ASSISE AVANT PASSAGER REGLARE SUPORT LOMBAR PASAGER
COMPACT DISQUE MONTARE COMPACT DISCURI
SYSTÈME DE NAVIGATION CU SISTEM DE NAVIGATIE CU ECRAN COLOR
LAMPES DE PROJECTEURS LAMPA CU DESCARCARE
LÈVE-VITRE ARRIÈRE MECANISM DE ACTIONARE ELECTRICA GEAM SPATE CU COMANDA SECVENTIALA + BLOCARE
AFFICHEUR AFISAJ (NAVIGATIE+VIDEO+RADIO+CEAS,T°,CD)
MIROIR DE COURTOISIE OGLINDA CONDUCATOR + PASAGER ILUMINATA CU CAPAC
INDICATEUR D’HUILE SENZOR CU FUNCTIE DUBLA NIVEL + TEMPERATURA ULEI
NAPPE CHAUFFANTE SCAUN CU INCALZIRE
SAC GONFLABLE LATÉRAL AVANT AIRBAG LATERAL ZONA TORACE FATA + SPATE + AIRBAG CORTINA
ECLAIRAGE BAS HABITACLE FARA ILUMINAT INFERIOR DE HABITACLU
NEUTRALISATION COUSSIN GONFLABLE DEZACTIVARE MANUALA AIRBAG
PROJECTEUR CORRECTEUR ASSIETTE REGLARE AUTOMATA A PROIECTOARELOR
PROJECTEUR DIRECTIONNEL FARA PROIECTOR DIRECTIONAL
RÉCEPTEUR RADIO SISTEM RADIOTELEFON "RT3"
RÉFRIGÉRATION SISTEM DE REFRIGERARE AUTOMATA
RÉGULATEUR DE VITESSES SISTEM DE REGULARIZARE VITEZA
REHAUSSE ASSISE AVANT CONDUCTEUR SISTEM DE INALTARE PERNA SCAUN CONDUCATOR CU REGLARE ELECTRICA
RÉTROVISEUR INTÉRIEUR RETROVIZOR INTERIOR CROMAT ELECTROCHIMIC CU POZITII ZI-NOAPTE
RÉGULATION CLIMATISATION / TEMPÉRATURE SISTEM DE REFRIGERARE AUTOMATA CU DOUA ZONE
TUNER-RADIO TUNER DUBLU RADIO
PROTECTION INTÉRIEURE FARA PROTECTIE INTERIOARA
DÉTECTION D’OBSTACLE DETECTOR DE OBSTACOLE SPATE
STORES LATÉRAUX TRANSPERANTE LATERALE "RAND 2"
ADAPTATION GARNITURE MANER MANETA DE VITEZE PIELE
AMPLI-ÉQUALISEUR CU AMPLIFICATOR EGALIZATOR
COMMANDE VERROUILLAGE BLOCARE PRIN SUPRA INCHIDERE
VOLANT VOLAN IMBRACAT IN PIELE CU 4 BRATE
SAC GONFLABLE GENOUX CONDUCTEUR AIRBAG ZONA GENUNCHI CONDUCATOR
Electricitate
ALTERNATEUR ALTERNATOR CLASA 18
BATTERIE BATERIE L3 450
DÉMARREUR DEMAROR CLASA 6+
ECLAIREMENT PARTICULIER APRINDERE AUTOMATA A LUMINILOR
FRÉQUENCE RADIO FRECVENTA RADIO ASIA
Marci echipamente
Diverse
CRITÈRE VARIANCE, CLIENTÈLE CONCEPTION STANDARD
ATMOSPHÈRE ATMOSFERA NORMALA
ROULAGE DRUM CORECT
"FRECVENTA RADIO ASIA " -se corecteaza cu diagnoza
Activarea pentru senzorii de parcare spate (vizualizare ecran) se face din BSI :
Imagine Imagine
Bonus-functie prezenta la VAG daca se lasa maneta semnalizatorului cuplata ramine pozitia pe partea respectiva aprinsa.
Spor.
Înapoi la “Audio&Navi”
