Citroen C4 a murit...traiasca noul C4 Cactus
Articolele din presa straina nu vor fi traduse in romaneste. Puteti folosi google translate daca nu va descurcati!
- Vasea
- Marca si model masina:Renault Scenic 2, 1.6 b, 2006
- Localitate:IASI
Citroen Axes C4 Hatchback, New C4 Cactus Takes Its Place At The Range
http://www.carscoops.com/2017/10/citroe ... actus.html" onclick="window.open(this.href);return false;
Citroen will drop the C4 hatchback from its range and doesn’t plan a direct replacement up until 2020, leaving temporarily the C4 Cactus as the sole player in the compact segment.
That’s why the French car-maker made the extra effort and significantly re-engineered the Cactus, making it the first European model to come fitted with its new hydraulic suspension, as it targets now to a much wider audience.
An all-new replacement for the C4 hatchback won’t be ready up until 2020 or 2021 while the new C4 Cactus will be launched in Europe at the start of 2018.
“The current C4 is a seven-year-old design and we had to make a decision. We will stop production and the C4 Cactus will take its place,” said Xavier Peugeot, product planning boss to Autocar.
Apart from the new hydraulic suspension, the new C4 Cactus comes with 80 percent new body panels and a more premium front end with extra bits of chrome. Citroen has also added new optional seats that are filled with high-density foam for even more comfort.
“We are talking here about 21st-century comfort in suspension and seats. But it is more than that, Citroën is about well-being and peace of mind,” said Citroën boss Linda Jackson.
Refreshed Citroen C4 Cactus Gains Hydraulic Suspension For A Smoother Ride
http://www.carscoops.com/2017/10/refres ... gains.html" onclick="window.open(this.href);return false;
Citroen has pulled the wraps of their facelifted C4 Cactus, which becomes the first European model to offer the company’s new Progressive Hydraulic Cushion (PHC) suspension.
The system debuted with the C5 Aircross and aims to give the more affordable C4 Cactus a buttery smooth and comfortable ride through a set of secondary hydraulic dampers in each corner which replace the conventional bumpstops at both ends.
Citroen has opted for a more comfortable set of the regular springs and dampers in order to further cushion the ride quality. The French company has also redesigned the seats which are now filled with high-density foam for even more comfort over longer drives.
Part of the update is of course the new exterior look of the C4 Cactus, which continues to feature the signature Airbumps, only now they’re mounted just above the sills and are smaller in size.
Other changes include new bumpers front and back along with physically larger lights all around, making the 2018 C4 Cactus look a lot cleaner. Citroen will offer 31 different exterior color combos and a range of five alloy designs to choose from.
Autonomous emergency braking, traffic sign recognition and a driver attention warning system are now part of the new model’s equipment, along with blind spot monitoring, park assist and a rear-view camera. The infotainment features a seven-inch touchscreen display.
Citroen has also added a new engine option in the C4 Cactus range with the 130PS 1.2-litre PureTech engine. The same engine is also offered in 82PS and 110PS versions while there’s also a 100PS diesel.
Noul Citroen C4 Cactus: sistem Airbumps redus, confort sporit și suspensie hidraulică
http://www.automarket.ro/stiri/noul-cit ... 80655.html" onclick="window.open(this.href);return false;
Citroen C4 Cactus a primit o actualizare care include o reducere semnificativă a sistemului Airbumps și introducerea suspensiei hidraulice PHC. Modelul este poziționat acum drept un hatchback compact care înlocuiește C4.
Citroen a anunțat joi câteva schimbări importante pentru C4 Cactus. În ciuda faptului că SUV-ul ar fi trebuit să primească doar un facelift, constructorul francez evită acest termen ca urmare a faptului că poziționează acum modelul ca hatchback compact.
Modificarea apare pentru a scoate în evidență că gama de SUV-uri Citroen este alcătuită acum din modele lansate sub brandul Aircross, în timp ce C4 Cactus este considerat doar un înlocuitor pentru C4, a cărui producție a fost întreruptă.
Citroen C4 Cactus: date esențiale:
● blocurile optice, aripile față și ușile au un design ușor modificat, în timp ce stopurile beneficiază de o semnătură LED cu efect 3D;
● francezii renunță aproape complet la sistemul Airbumps. Prezent inițial pe o suprafață generoasă a ușilor din față, acesta este vizibil acum doar în partea inferioară a portierelor cu scopul de a oferi un aspect estetic mai discret și tradițional. Sistemul Airbumps este alcătuit din capsule de aer integrate în ornamentele care îmbracă portierele pentru a evita zgârieturile şi avariile caroseriei care au loc în parcări;
● modelul oferă 5 tipuri de jante din aliaj de 16 inch și 17 inch;
● volumul portbagajului este de 358 de litri și crește la 1.170 de litri în cazul rabatării banchetei din spate;
● Citroen oferă 31 de posibilități de personalizare prin intermediul a 9 culori pentru caroserie și a patru pachete speciale Color Packs;
● C4 Cactus devine primul model european al francezilor care folosește o suspensie hidraulică Progressive Hydraulic Cushions (PHC) care înlocuiește astfel suspensia pneumatică;
● utilizarea noii suspensii oferă un confort sporit pentru pasageri, care beneficiază și de noile scaune Advanced Comfort prin care postura este îmbunătățită;
● modelul include și 5 ambianțe diferite pentru interior, car se deosebesc în special prin tapițeria folosită pentru scaune și culoarea plansei de bord: Standard, Metropolitan Red, Wild Grey, Hype Grey și Hype Red;
● pe consola centrală există un spațiu de stocare generos, priză de 12 V și porturi USB, în timp ce în portiere poți depozita și sticle de 1.5 litri;
● Citroen oferă 3 tehnologii de conectivitate: Mirror Screen Function compatibil cu Android Auto și Apple CarPlay, Connect Nav (cu sistem de navigație TomTom și ecran de 7 inch) și Connect Box (cu sistem de alertare automată a serviciilor de ambulanță în cazul unui accident);
● gama de motorizări rămâne neschimbată. Fanii motoarelor pe benzină au la dispoziție unitățile PureTech de 1.2 litri și 82 CP cu cutie manuală și PureTech de 1.2 litri și 110 CP și 130 CP, în timp ce fanii diesel au la dispoziție doar motorul BlueHDi de 1.6 litri și 100 CP. În toamna anului viitor va apărea însă și o versiune de 120 CP a motorului BlueHDi;
● noul C4 Cactus este disponibil cu 12 sisteme de asitenta, printre care Active Safety Brake, Speed Sign Recognition, Lane Departure Warning System, Blind Spot Monitoring System sau Park Assist.
Via Autocar, L'Automobile, Caradisiac, L'Argus
- wonka jr.
- Marca si model masina:Citroen DS3 1.6 hdi 92 cp
- Numar Inmatriculare:GL 88 WNK
- Localitate:Galati / Bucuresti
Re: Citroen C4 a murit...traiasca noul C4 Cactus
sunt curios daca minunata suspensie va fi oferita in standard pe toate versiunile.
- stevey
- Marca si model masina:C4 1.6i BLACK
- Localitate:Iasi/Bucuresti
Tor designul c4-ului mk 1 (non face-lift) va ramane iconic pt Citroen si in lumea auto deopotriva. Mk 2 a fost o masina banala inca de la inceput, iar noile modele si schimbarile astea brusce de strategii arata clar lipsa unei directii mai clare a Citroen.
- Vasea
- Localitate:IASI
Zona de confort – Test cu noul Citroen C4 Cactus
http://voom.ro/zona-de-confort-test-cu- ... c4-cactus/" onclick="window.open(this.href);return false;
Drive-test Citroen C4 Cactus - 1.2 Benzina Turbo (PureTech) 110CP Aut6 Shine
http://www.automarket.ro/test-drive/tes ... 84783.html" onclick="window.open(this.href);return false;
Cine a fost la - https://www.lansare-noul-c4-cactus.ro/" onclick="window.open(this.href);return false; ???
Noul Citroën C4 CACTUS HATCHBACK te aşteaptă în showroom-urile noastre din toată țara. Participă la tombolă și poți câștiga o vacanță în doi sau unul dintre celelalte 5 premii surpriză.
- Marca si model masina:ASDSADSADSADSGFDGFDGFDGFDGFDGFDGDF
Vreau și eu unul?
- Davos
- Marca si model masina:Citroen C4 Picasso 2.0 BlueHDI BVA
- Numar Inmatriculare:B92PNM
- Localitate:BUCURESTI
Acum... după doi ani de la postare?...prea târziu...nu se mai găsesc.
- Vasea
- Localitate:IASI
Citroën C4 Cactus Successor Makes Spy Debut As Higher-Riding Crossover Coupe
https://www.carscoops.com/2020/01/citro ... ver-coupe/
Citroën C4 Cactus Given ‘C-Series’ Special Edition Treatment For 2020
https://www.carscoops.com/2020/01/citro ... -for-2020/
Citroen C4 Cactus Successor Confirmed For 2020 With Battery-Electric Option
https://www.carscoops.com/2019/11/citro ... ic-option/
Citroen C4 Cactus Replacement Spied For The First Time
https://www.motor1.com/news/394174/citr ... ver-spied/
- Vasea
- Localitate:IASI
Detalii despre noua generație Citroen C4: motoare diesel și pe benzină de până la 155 CP și versiune electrică cu autonomie de 350 de kilometri
https://www.automarket.ro/stiri/detalii ... 98821.html
Este oficial asata arata noul Citroen C 4 2020! Motoare pe benzina, diesel insa si electrice
http://www.autolatest.ro/stiri-masini/e ... -electrice
Citroen ë-C4 - 100% ëlectric vine pe piata chiar inainte de VW eGolf 8! Francezii domina segmentul electric
http://www.autolatest.ro/stiri-masini/c ... l-electric
