Xenon pe C4
- Localitate:Bucuresti
It seems that you have some quality xenons(in my oppinion). Could be an installation problem?!?
- muntos
- Numar Inmatriculare:B-333-VTS
- mituc
- Localitate:Iasi
Hello coolman,coolman_kk scrie:Before 5-6 days install xenon kit Well-Done on my car, but have a big problem When passing through a hole or rail, xenon bulbs tremble
Somebody with xenon kit have this problem?
It is normal for the bulbs to tremble a little bit, otherwise they would absorb too much of the shock and they can shatter.
But they should not tremble too much and too easy, you should pass through a pretty big hole to see them trembling.
But if they do tremble then probably the guy who installed them didn't fix them too well and probably that rubber fixing from the bulb socket is not correctly mounted. This can lead to some other problems, like watter inside the headlight, because the fixing is too permissive for water (let's hope not) and outside air (which can condense watter due too high or too variable air humidity).
- Shadow
- AfterDark Racing Club
Incearca pe www.nescar.ro kitul M-tec, sau cauta pe net Hella.muntos scrie:Recomandati-mi si mie un kit bun de xenoane va rog.
Daca vreau sa pun xenon pe ambele faze, imi trebuiesc 2 kituri xenon sau un kit bi-xenon? Adica C4 are 2 becuri pe far sau unul singur ?
- Ovidiu
- El_Rey
- Marca si model masina:AUDI A6 2013 2.0TDI
VW POLO 2007 1.4i - Numar Inmatriculare:BXX5EBI
- Localitate:BUCURESTI
dar de kit-urile SiemensHID 2007 ? am vazut chestii interesante pe www.xenonauto.ro!!! Ei se lauda ca ar fi foarte bune! Ceva pareri?
- muntos
- Shadow
- Ovidiu
- El_Rey
- silvius
- Numar Inmatriculare:B08BBK
- Localitate:Bucuresti / Varna
pai e relativ simplu, doar ca ai cele doua balasturi care trebuiesc prinse. Oricum nu pune orice porcarie ca nu merita. Pune ceva k lumea. Deobicei de unde cumperi iti si monteaza. Daca vrei si te hotarasti poti sa ma suni.
- mituc
- Localitate:Iasi
Asa, deci deocamdata mie mi s-a ars un xenon de pe dreapta din setul de la Doc. Se pare ca aceste tirfe infecte numite "edili", aceste scroafe ale societatii care s-ar simti mult mai bine daca in loc de aparatul din dotare as avea o punte de camion si 2 rezervoare de C4 pline cu 60l de ******enii, acesti nesatui purici ai tarii care ar trebui hraniti cu vidanja, au aprobat lucrari care presupun spargerea asfaltului acum iarna cind bineinteles ca ratatii de la salubris nu asfalteaza nici un ckt nimic. N-au asfaltat asta vara, cum puii mei sa asfalteze acum?!
Sa nu acrosezi cu cu acceleratia la fund orice tuaregar se da jos din caruta lui 3.0V6 TeDeI oprit fiind in cele mai imposibile locuri cu avariile aprinse? Largi-le-as esofagele sa le intre mai mult sa se sature!
- nero
- Robotizat
Tare asta, n-am stiut-oShadow scrie:Masinile care au xenon pe ambele faza din fabrica, mai au un bec suplimentar cu halogen pt flashuri.
Mi se parea mie mai ciudat pentru ca xenonul nu se aprinde instant ci ii ia cam o secunda sa ajunga la intensitatea maxima, chiar ma intrebam ce se intampla la flash-uri.
Deci sa inteleg ca becul de pe interior e de fapt halogen, iar ambele faze cu xenon sunt prin lupa din exterior?
Citroen C4 - 1.6HDI - SX Pack
- newt
- CPatratzel
- Marca si model masina:Mercedes-Benz CLA 250 4matic
- vladut_v
- nero
- Robotizat
- vladut_v
Noaptea se vede diferenta.
Cand dai flash cu restul luminilor stinse, ai lumina galbuie, de halogen.
Cand ai faza scurta ON, poti sa ti maneta apasata (ca un flash lung), iar cand o apesi si mai tare (pana comuta pe lunga) vei vedea (si vei si auzi) cum lupa de xenon isi modifica pozitia pentru a furniza faza lunga pe xenon). Practic se lungeste bataia fascicolului de xenon, parca se si largeste unghiul spre laterale. Poate ai observat ca faza scurta de xenon se termina brusc la o lungime nu foarte mare, nu se "pierde" in departare ca un halogen. E si deranjant la viteza mare.
Ti-am lasat un PM, nero !
C4 1.6i 16V Berlina
