C4 WRC Kit Car
Totul despre divizia sport a Citroen
ClubC4
C4 WRC Kit Car
Mesaj de ClubC4 »
Citroën C4 WRC este un vehicul care simbolizeaza reînnoireamarcii . Acesta a fost rezultatul cooperării dintre inginerii de la styling si sport. La inceput, proiectul a ignorat complet cerinţele de reglementare. Un adevărat exerciţiu de stil, este întâlnit cu provocarea de a dezvolta o viziune futurista a unei masini noi. O masina pentru a înlocui Xsara WRC, castigatoare de trei ori a titlului "producători" între 2003 şi 2005. In mana expertilor Citroën Sport Satory inginerii de la Versailles, conceptul C4 Sport a devenit C4 WRC.
Caracteristici tehnice Citroën C4 WRC :
Engine
Turbocharged
Developed from the XU7JP4 engine
Layout: crosswise, tilted 25° towards the exhaust
Number of cylinders: 4 in line
Aluminium block
Capacity (cm3): 1,998
Max power (bhp – rpm): 315 at 5,500
Max torque (mkg – rpm): 58 at 2,750
Timing
2 overhead camshafts driven by a toothed belt
4 valves per cylinder
Power supply
Magneti-Marelli multipoint injection
Type: 2KR
Transmission
4WD
Carbon three disc clutch
Mechanical differentials on the front and rear axles – electronically controlled at the centre
Sequentially controlled 6-speed semi-automatic gearbox
Front brakes
Asphalt: ventilated discs, 6-pot callipers
Gravel: ventilated discs, 4-pot callipers
Rear brakes
Asphalt and gravel: ventilated discs, 4-pot callipers
Front/rear distribution adjustable by a compensator
Hydraulic handbrake
Suspension
Front and rear: MacPherson type with coil spring
Citroën / Exe-TC dampers
Steering
Hydraulic power assisted
Wheels
Asphalt: 8 x 18 inch
Gravel: 7 x 15 inch
Goodrich Asphalt BF tyres: 225/40-18
Goodrich Gravel BF tyres: 215/65-15
Dimensions
Length: 4,274 mm
Width: 1,800 mm
Wheelbase: 2,608 mm
Front/rear track: 1,598 mm
Weight
1,230 kg (minimum authorised)
Imagine Imagine Imagine
Imagine ImagineImagine
Va URMA :wink:
Re: C4 WRC Kit Car
Sublim, de ce nu vor sa puna turbarea intr-o berlina cu 5 usi nu inteleg. Nu-i trebuie 315CP si aproape 600N*m, doar 250cp si 400N*m.
Re: C4 WRC Kit Car
eheee mituc la anul prin aprilie vei avea o surpriza referitor la C4...se anunta o noua editie by Loeb aprox 200 cp. Ti`ai da mazda pe asa ceva? :mrgreen:
Numar Inmatriculare: B 35 DOX
Localitate: Bucuresti/Cernica
Re: C4 WRC Kit Car
Mesaj de Dan pasare »
Mihay scrie:...se anunta o noua editie by Loeb aprox 200 cp........
Sigur? :roll: Ca sa ma apuc sa strang bani :mrgreen:
Re: C4 WRC Kit Car
vezi daca ai lipsit joi seara :wink:
Re: C4 WRC Kit Car
Mihay scrie:eheee mituc la anul prin aprilie vei avea o surpriza referitor la C4...se anunta o noua editie by Loeb aprox 200 cp. Ti`ai da mazda pe asa ceva? :mrgreen:
Nu o da ca el vrea 4 usi nu 2 :D :D
Re: C4 WRC Kit Car
Exact. Dar daca as cistiga la loto cu asta m-as baga in VTM si apoi rally.
basy
Praz Racing Team
Re: C4 WRC Kit Car
Mesaj de basy »
nu prea ai ce sa faci acolo cu asa ceva, poate doar mana si figuratie, un WRC ar fi insa cu totul altceva.
Re: C4 WRC Kit Car
bai cit costa un kit car dintr-asta?
Re: C4 WRC Kit Car
mult de tot...cred ca in jur de 2-300 000 euro. eu eram curios de altceva si poate isi face timp mugurel sa ne explice : in afara de forma caroseriei ce mai e cat de cat comun cu ce avem noi(sunt unele piese obligatorii parca) si la motorul nostru tu5jp4 sau cat e ce e comun cu super 1600 de pe c2
Re: C4 WRC Kit Car
Mugurel zicea ca ar putea sa aduca kitul de WRC..caroseria, dar isi punea problema ce faci cu rotile ca nu se vor mai vedea la cat de evazata este!! :P
Re: C4 WRC Kit Car
gasesti replici la vreo 2000 eur...
cat despre roti...distantiere dalea imense.....dar nu mai mergi cu ea la servici...
Re: C4 WRC Kit Car
cred ca se refera la masina cu totul nu la kitul ala de caroserie de pe ebay
Re: C4 WRC Kit Car
KIT ma nu masina!!
Cezar
pi buni
Re: C4 WRC Kit Car
Mesaj de Cezar »
Despre un kit zicea. Dar a zis ca e problema cu rotile.
Si ca nu ar fi o solutie distantierele. Ar arata ca naiba.
Înapoi la “Citroen Racing”
