Acest proiect nu este insa primul in ce priveste Fiesta Super 2000. In urma cu 2 ani, Ford Australia a incercat sa contruiasca un model Fiesta dupa regulile Super 2000 prin converitrea unui Fiesta S1600 achizitionat din Italia. Operatiunea a reusit, insa masina nu a concurat decat in acel sezon.
Noul model va fi omologat de FIA din 1 ianuarie 2010 si Malcolm Wilson doreste ca masina sa ruleze in mana pilotilor privati inca de la inceputul sezonului viitor in Cupa S2000 din WRC.
Fiesta S2000 vine dotata cu un motor 1998 cc I4 Duratec S2000, care scoate la inaintare nici mai mult, nici mai putin de 280 CP la 8000 Rpm. Toate acestea combinate cu o cutie de viteze manuala, ambreiaj AP, frane Brembo imense care, ca si jantele, isi schimba dimensiunea in functie de asfalt sau pietris alcatuiesc "Ce n-a vazut Parisul".
[youtube] http://www.youtube.com/user/S2000Fiesta ... FsEwVMItpk" onclick="window.open(this.href);return false; [/youtube]
Ford Fiesta S2000 Technical Specification
Engine:
Ford 1998cc Pipo built I4 Duratec S2000 engine. Four cylinders, 16 valves.
Bore 87mm. Stroke 83mm. Cosworth electronics engine management system. Catalytic converter.
Power:
280 bhp at 8000 rpm.
Torque:
260 Nm at 6500 rpm.
Transmission:
Permanent four-wheel drive. M-Sport / Xtrac six speed sequential gearbox with AP clutch.
Suspension:
Front and rear: MacPherson struts with Reiger external reservoir dampers, three-way adjustable. Fully adjustable fabricated steel links. Front and rear anti-roll bars. Machined aluminium uprights.
Brakes:
Gravel (front and rear): 300mm Brembo ventilated discs with Brembo four piston monoblock calipers.
Asphalt (front ): 355mm Brembo ventilated discs with Brembo four-piston monoblock calipers.
Asphalt (rear ): 300mm Brembo ventilated discs with Brembo four-piston monoblock calipers.
Hydraulic handbrake.
Steering:
Power-assisted high-ratio (12:1) rack and pinion. One and a half turns lock to lock.
Wheels:
Gravel: 7in x 15in (aluminium) wheels with 650mm tyres.
Asphalt: 8in x 18in (magnesium) wheels with 650mm tyres.
Bodyshell:
Unitary construction. Unique composite side panels. Welded T45 steel safety roll cage. Aerodynamic rear wing. Unique front 'bumper' treatment.
Electronics:
Full Cosworth electronics data acquisition for on-event diagnostics and performance development.
Fuel tank:
FIA FT3 tank, 80 litre capacity, located centrally.
Dimensions:
Length: 3958mm. Width: 1820mm. Wheelbase: 2489mm. Weight: 1200kg minimum.
