Specifications:
Sensor:1/3"Color CMOS, PC1030
Resolution:648(H)*488(V)
lens angle:170 degree
Resolution: 420 TV Lines
Shutter speed: 1/60s-20us
Waterproof: IP67
Minimum illumination: 0.4Lux
Working Voltage: 8-12V
Working Temperature:-20℃~+70℃
TV System: NTSC/PAL( We will be based on your area, take the initiative to match the appropriate output system NTSC or PAL. If you have special requests please sent me a email from ebay, or left a note after you had paid the item )
Unique Design,With reference line functions you can turn it off.
Package Included :
1x Waterproof Cmos Color Camera
1x 5 Meters AV Cable
1x Power Cable
1 x User Manual
How to Install :
1:Take out your stock license plate light at the back of your car.
2:Fix the camera to where the stock license plate light was.
3:Connect the built-in license plate light of the camera to where the
stock license plate light was connected to get the power .
4:Connect the power of the camera to your brake lights - red wire to
positive and black wire to negative.
5:Connect the video cable of the camera to the extension cord.
6:Connect the extension cord to your car monitor.
7:You will see the images when your car is in reverse shift.
SE MONTEAZA IN LOCUL LAMPEI DE LA NR.!!
