Site - Verificare campanii de rechemari
Asa cum scrie si in subiect, AICI puteti cauta campaniile de rechemari pt. masina voastra. Nu stiu daca sunt toate valabile, dar nu vad de ce nu ar fi daca seria masinii se incadreaza in campanie.
- horas
Re: Site - Verificare campanii de rechemari
Multumim norishor
Interesant ce am gasit la mine:
R/2008/051
THE BRAKE PEDAL COULD BECOME STIFF THEREBY REDUCING BRAKING ASSISTANCE
The brake pedal might feel stiff and the braking distances extended as a result of a defect in the vacuum pump
Recall the vehicles that are likely to be affected to replace the valve in the vacuum pump
VF7******74459011 to VF7******76796753
R/2008/051
CITROEN C4 1.6 16V SX VTR
Da un telefon/mail la Citroen Romania cat mai poti, si intreaba i daca exista pentru tine vreo campanie de rechemare!
- danmanea
- Numar Inmatriculare: B-37-JXR
Uuuuu...
si la mine:
Reference : R/2012/048
Manufacturer Ref : MPX
Make: CITROEN
Model : C4 & DS4
Launch Date : 23/04/2012
Numbers Involved : 78
Build Start Date : 13/10/2011
Build End Date : 15/11/2011
Concern : VEHICLE MAY CUT OUT
Description :
The supply terminal to the engine relay unit may have been over tightened and over time this could damage the component and cause the engine to cut out. In addition this could cause the diagnostic warning lamp to illuminate in error and it may make it more difficult to start the engine.
Remedial Action :
Recall the vehicles that are likely to be affected to check and if necessary replace the engine relay unit.
Vehicle Id :
VF7******BY580054 to VF7******BY638057
si la mine:
Make: CITROEN
Model : C4 & DS4
Description :
Remedial Action :
Vehicle Id :
- teddy_dmy
hop si eu....
Recall Details
Concern : SHORT CIRCUIT MAY OCCUR/RISK OF FIRE
Description : Repeated ingress of saline water into the connections to the Electronic Control Unit for the Anti- Lock Braking system may eventually result in a short circuit that could cause a fire in the engine compartment.
Remedial Action : Recall the vehicles that are likely to be affected to check the ABS block and strengthen the sealing of the electrical connections.
Vehicle Id : VF7******74144020 to VF7******74321169
Recall Details
- horas
mda, se pare ca nu sunt valabile pentru Romania.
Nu au fost lansate de catre Citroen Romania inca.
Daca se vor lansa si in Romania cu siguranta ne vor anunta cei de la Trust Motors
- mihai ham
- Marca si model masina: Citroen C3 Picasso,1.6 HDI
- Numar Inmatriculare: VL
- Localitate: Vâlcea
Verificat
,fără rechemare
- Raducv
- Localitate: Craiova
Ce zici tu aici suna cam fishy! Daca o masina are o problema cunoscuta ce conteaza tara atat timp cat rechemarile se fac pe VIN! Evident ca trebuie o directiva data!horas scrie:mda, se pare ca nu sunt valabile pentru Romania.
Exact! Pana la urma masina aia are o pb cunoscuta. NU ar trebui sa conteze din ce tara esti. Problema masinii nu cred ca tine cont de tara, atunci cand apare. Dar nah .. e mai bine sa "ascunda" decat sa recunoasca. Eu cred ca ar trebui facute ceva presiuni.Bogdan scrie: Ce zici tu aici suna cam fishy! Daca o masina are o problema cunoscuta ce conteaza tara atat timp cat rechemarile se fac pe VIN! Evident ca trebuie o directiva data!
Unde si cui? De asemenea siteul care l ai pus tu, ce e cu el? E ceva oficial sa te poti baza 100% si sa il ai ca referinta cand ridici problema?
- catalin4u24
- StarShip Pilot
Bogdane, site-ul este cat se poate de autentic si de luat in considerare o data ce are gov.uk in adresa (site-ul guvernului Marii Britanii).
Cat despre VOSA, este o institutie de stat gen RAR Romania, ce are o baza de data cu toate masinile inregistrate in UK si nu numai. La mine toate MOT-urile (verificarile tehnice anuale) au stampila VOSA. De asemenea mai am si un certificat VOSA care atesta ca masina n-a suferit nici un accident, deci baza de date comuna cu firmele de asigurari.
Acum cat de relevanta este pentru RO... nu stiu, ce putere poate avea daca se aduce in discutie la o adica...
Eu am vazut ce comunicare slaba este intre o institutie din uk cu una din ro, nu numai din intamplarea cu asigurarea masinii anulata in uk din cauza proastei comunicari dar si cand am aplicat pentru alocatia copilului... deci comunicarea este 0.
Pai eu nu ma astept ca cineva din Romania sa reactioneze..nici nu prea ar avea cum, in cel mai bun caz poate doar sa intrebe si ei mai departe..insa ar trebui dat un mail cui trebuie din Franta facand referire la acel site, si intrebat de ce in ROmania nu se aplica!
- danmanea
Am intrebat la Trust Motors.
Am primit raspuns:
Stimate domnule Dan Manea,
Link-ul pe care ni l-ati oferit este cu referire stricta la vehiculele comercializate pe teritoriul UK, iar campania respectiva este specifica acestei tari.
Va confirmam in urma verificarii in baza de date a Citroen ca vehiculul pe care il detineti nu face parte din lotul de 78 de vehicule incluse in aceasta campanie de rechemare.
Cu stima,
Raluca Otoiu
Responsabil Relatii Clienti
Trust Motors S.R.L.
Blvd. Iuliu Maniu 572-574, Sector 6,
061129 Bucuresti, ROMANIA
Tel: +40 21 207 77 30
Fax: +40 21 207 77 29
Mobile:
E-mail: raluca.otoiu@trustmotors.ro
http://www.peugeot.com.ro" onclick="window.open(this.href);return false;
Am primit raspuns:
Cu stima,
Raluca Otoiu
Trust Motors S.R.L.
Mobile:
- danmanea
Am reusit sa dau de Citroen pe Twitter... in rest.. pe site-ul lor doar parteneri.Bogdan scrie:Pai eu nu ma astept ca cineva din Romania sa reactioneze..nici nu prea ar avea cum, in cel mai bun caz poate doar sa intrebe si ei mai departe..insa ar trebui dat un mail cui trebuie din Franta facand referire la acel site, si intrebat de ce in ROmania nu se aplica!
https://twitter.com/Citroen
Am intrebat acolo, direct message etc... cica au dat catre Romania.
Raspunsul primit de mine a fost in urma unui mail dat direct catre Trust Motors.
