Erori BSI, BSM
Totul despre C4 Picasso
laurg73
Marca si model masina: Citroen C4 Picasso 1,6 ehdi
Erori BSI, BSM
Mesaj de laurg73 »
Știe cineva cum se pot rezolva erorile acestea două?
State of the ECU: BSM
"C9A8 : exhaust heat recovery system coolant pump control fault"
Characterisation : open circuit
State of the ECU: BSI
"C9A8 : engine fusebox : Fault in the coolant pump control circuit for the exhaust heat saver system"
Multumesc
Re: Erori BSI, BSM
Defect de comanda pompa de apa a sistemului de recuperare a energiei termice a gazelor de esapament : Circuit deschis
Da-mi o serie de sasiu sa vad daca gasesc ceva specific seriei tale.
